In trying to set up my DD12 today, when turning both sub & amp volume down to zero, the frezuency response graph was showing substantial bass noise. Does this suggest a problem with the microphone?
When the volumes are turned down then there should not be any kind of response on the graph unless you have alot of ambient noise in the room ?
I would do a full reset on the sub by pressing 8,9,0 and see how you get on, if no joy then get intouch with you're dealer to see what he says i'm sure it will get sorted quickly as the DD12 is a flagship product...
