Problems with TV Link (Magic Eye) and Sky+
Discussion in 'Cables & Switches' started by GeeTee, Jan 13, 2008.
  1. GeeTee
    GeeTee
    Jan 10, 2008
    5
    Hi folks,
    I recently bought a length of coaxial cable, a second Sky+ remote and a TV Link magic eye (see link here: http://cgi.ebay.co.uk/SKY-PLUS-NEW-V...QQcmdZViewItem) so that I can view Sky in another room.
    I connected the coaxial cable to the RF Out socket on the back of my Sky+ box and put the other end into the TV Link before connecting in to the aerial socket in the back of my other TV.
    When I finished and turned the TV, it picked up the Sky signal fine, and now I can watch the same picture in both rooms. However, the TV Link doesn’t appear to work.
    I can’t change the channel or access any of the functions unless I get up and go through to the other room and point it at the Sky+ box.
    Can anyone suggest where I’m going wrong?
    Yours frustratedly,
    Allan
  2. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,893
    2
    The Fylde Coast
    +13,534
    The coax needs to be on the RF2 socket, not the RF socket. RF2 has the voltage output to drive the Link.
    Oh, and if I remember correctly you have to turn the voltage on in one of the Sky menus.
    EDIT To get to the menu do this:
    Services
    System Setup
    0 0 1 SELECT (yes press 0, 0 again, 1 and Select; it's a hidden menu)
    Second option RF VOLTAGE
    SAVE settings
    That should be it.
  3. joebre
    joebre
    Dec 20, 2006
    102
    Crossmaglen
    +3
    Mr. Incredible,
    I had recent troubles witha Sky Magic eye even though I had RF2 enabled.
    I think the menu option that you mean is Services, 4, 0 1, Select.
    Hope I'm right.
    joebre
  4. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,893
    2
    The Fylde Coast
    +13,534
    Did you RF output go through any splitters / amplifiers / wallplates which could have blocked the voltage?
  5. joebre
    joebre
    Dec 20, 2006
    102
    Crossmaglen
    +3
    Not at all. Cable run was about 20 straight run. Even had no wall plate at rear of TV. Had TV picture but no voltage when tested with a meter. Changed connection to RF + adaptor at back of Sky box and suddenly, magic eye worked.
    Have another run to my kitchen. Again, have picture bot no voltage. 2 joints using RF connectors along this cable run. Cannot run new cable without joints. Wll open RF joint in middle and see if eye works at that point !
    joe
  6. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,893
    2
    The Fylde Coast
    +13,534
    Probably a fault box in that it cannot sustain the voltage over a long length.
    In my set up the RF2 outputs to a wallplate which feeds into the roof on two Loft Boxes and then has a 5m run and splits and the Magic eye works fine. You sound to have a bit of bad luck with yours.
