Problems with Toshiba SD340E (multiregion)
Discussion in 'Blu-ray & DVD Players & Recorders' started by iws, Jun 10, 2005.
  1. iws
    iws
    Hi all,
    I bought a Toshiba SD340E (multiregion) a few months ago. I was really pleased with it at the beginning as it supported Divx, ... However, after a while I realised that it does not play all my DVDs which is really annyoing. (The most recent DVD which I bought is Dodgeball (region UK 2) and it did not play it (load - bad disc ...). The weird thing about it, the DVD worked with well my old Grundig DVD player which I had about for 3 years.
    Is this a common problem with this player?
  2. KoThreads
    KoThreads
    Jan 18, 2005
    3,012
    +179
    I'm afraid it is. Countless threads on the 340e and it's pros and cons, but mostly incompatibility with some original DVD's and most DVD-R's.
