Problems with the Scart on my Philips TV
Discussion in 'Televisions' started by qouz, Jan 5, 2003.
  1. qouz
    qouz
    Hello,
    I recently bought my self a dvd player which i connect to my Philips 32"8506 TV. The problem is when i use Scart1 when watching dvd films, i get the sound from a tv channel in the right speaker (i only hear this when the sound on the dvd film is low). This is quite annoying , and i wonder if it is a problem with my telly? Anyone observed a similar problem with their Philips TV?
    By the way, when i use Scart2 i dont get this problem, but he picture here is not as good as Scart 1 (haven't got a clue why...) so i prefer using scart1.
    Any comments anyone?
    qouz
    :mad:
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,100
    Manchester
    +712
    Probably only SCART 1 is RGB-enabled ; thus when you use SCART 2 you will get (inferior) composite video (Cvbs).
    I would try a different SCART lead, preferably one with all I/O connections screened.
    You could use an RGB-only SCART if your audio goes to an amp from the DVD-player via other means. You could also cut (or temporarily remove) unused connections (which will cut down on possible paths for crosstalk).
    Chris Muriel, Manchester.
