Problems with the Samsung HD850
Discussion in 'Blu-ray & DVD Players & Recorders' started by guyzee25, Jun 4, 2005.
  1. guyzee25
    guyzee25
    I just picked up the Samsung HD 850. I love the player, sleek, sexy, good playback but I have a large collection of movies on DVD+r/-r RW...
    The player advertises compatibility with all of the above, but I have several movies on DVD+r which it won't play. All the ones I have a problem with are on Fujifilm discs, my Memorex discs work just fine. Is there a reason why these certain discs won't work? It's very frustrating, has anyone else experienced any thing like this? Am I left to only buying a certain brand of DVD disc?
    Does anyone else have this model and do you have the same problem? If so are there any other writable discs that your set will not play?
    Thanking you in advance for your experience and wisdom,
    The Guy
  2. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    early samsung models had problesm with poor quality re-write discs and i think this will be the same .
    Phillips +rw no problesm 10 for 9.99 from currys
    Best way-also once recoreded the kids may press record-can write protect them
    Cool
    By the way does your 850 have 768p via HDMI ?
    Azz
  3. guyzee25
    guyzee25
    Yes, it does have the hdmi hookup and they supplied the cable. Unfortunately my panny plasma doesn't have hdmi hookup. :confused: But otherwise I love the player just wish it played 100% of my discs.
  4. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    It sounds like you've just come across some incompatible media. You'll need to buy some discs that do work and copy them to the new discs using a PC.
  5. gingerone
    gingerone
    Dec 10, 2002
    2,556
    +383
    This player is riddled with annoying little glitches, it could have been an awesome player if more thought had gone into making it more user friendly.
    I know it's only £90 but is it so had to iron out the little glitches before selling it?
    Still can't fault the playback.
