Problems with the Airboard keyboard.. help!
Discussion in 'Computer Peripherals & Consumables' started by pegFACE, Jan 27, 2002.
  1. pegFACE
    pegFACE
    Hello
    I recently bought an airboard and it was all working well untill it had patches of not working, and then working. Now its stopped totally, the reciever still works, but the transmitter is not sending any info...
    I know the batterys are good, I check them in other things
    Help!
  2. jlcrawford
    jlcrawford
    Mar 21, 2001
    491
    NE England
    +3
    I pulled out my 3 yr old IR keyboard and just plugged it in and rebooted the pc with win me - it worked fine .I bet your keyboard is faulty and would return it
  3. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,517
    7
    167
    Birmingham, UK
    +10,238
    I've had one airboard die on me in about a year.
    They're so cheap they're almost disposable.
    Once you've programmed your pronot, you shouldn't need one anyway.
