Hi everyone,
I hope I'm in the right section, i am with Sky broadband but seeing as it is a hardware problem i thought this section would be better suited.
Basically, since we have had sky our speed has been a bit inconsistent, varying between 2-4mb despite being told we should get 5.5mb. Anyway 10 days ago it dropped to 1.4mb and stayed at that so i rung them up to see if anything was up. They then told me that i needed to check to see whether it is an internal or external problem, so i took the master socket plate off and put the broadband filter straight into the test socket. All of a sudden my speed was up to 6mb and the phone line seemed clearer. So I left it a few days and the speed didn't change.
So the issue is internal. I put the face plate back on the master sock a bit earlier and the it is now showing is 2.4mb, so and improvement but certainly not the 6mb i could be getting. I have another phone socket in the house, which is being used, i have got a filter on there (just for added info).
Is it a case of putting on a new faceplate, if so how easy is that to do and what about wiring? Or is it potentially something more that requires an engineer?
Tom
Tom
