E
edhg
The problem is with the PS2 component link to the HS50 using a cable that I got from Liksang (click here). I plugged it in but no joy (when plugged both via my yamaha amp and then into the projector directly). I get nothing but a blue screen and every so often a message saying that the frequency is out of range. I had a look at the settings for the frequency which says that it is at 99.9Hz. I tried my DVD player which says about 50Hz. Is it a problem with the cable or the PS2? Can it be fixed? The PS2 is not modded at all and is the standard UK model.
thanks
Ed
thanks
Ed
