Problems with SONY KV-36FS76
Discussion in 'Televisions' started by rox, Jan 27, 2003.
  1. rox
    rox
    They have already changed two
    and both have the same problem.
    Can you verify if also to you it is like that
    with my same values?
    White titles on black background.
    Brightness: 3/4
    Contrast: 3/4
    Color: 3/4
    Please tell me that they are not all the same!!!
    the serial-numbers are 4000224 - 4000227
    Rox from Italy
  2. rox
    rox
    Sony KV 36FS76
    Rox
      Size:
      63.6 KB
      202
  3. rox
    rox
    Sony KV 36FS76
    Rox
      Size:
      37.1 KB
      186
  4. mattheu
    mattheu
    Brightness: 3/4
    Contrast: 3/4
    Color: 3/4
    what do you mean by this?
  5. Rookies
    Rookies
    Jan 4, 2003
    4,898
    103
    +344
    I think he means he got the bar set 3 quarter along the line
  6. rox
    rox
    >Brightness: 3/4
    >Contrast: 3/4
    >Color: 3/4
    As in the following image
    Rox
      Size:
      60.2 KB
      175
  7. Rookies
    Rookies
    Jan 4, 2003
    4,898
    103
    +344
    Jesus could not have mine that high the colour bee to bright not natruel in my though
  8. Lpool
    Lpool
    Mine is having the same "problem" When dark scenes there are dark blocks/lines/waves..difficult to describe...Can it be fixed?
  9. rox
    rox
    What's your serial number?
    Rox
  10. cdave
    cdave
    Dec 10, 2002
    306
    Not quite sure what is happening here but interesting to see the settings. Mine are all well below half! (this is different to my previous fs70 however which were more like the picture).
  11. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    i think these lines are the shadows i see on bright backgrounds!!!
  12. ScottyToo
    ScottyToo
    Oct 13, 2002
    94
    Essex, UK
    +3
    Am I the only one who finds the DRC50 better than DRC100.
    My DRC100 appears more like DRC off but with less flicker. i.e. I have slight lines between each pixel.
    In DTC50 I don't have any lines. Is this correct or do I have a prob?
    Cheers.
  13. the plumber
    the plumber
    Can you explain exactly what your fault is ????as this thread seems to start in mid flow ????and i cant understand what thefault is your referring to.
  14. rox
    rox
    Sorry for my English.......
    I have overdone the values to do the photo.....I thought it was obvious.
    The faults see also in "film" modality.
    Rox
  15. Markster
    Markster
    Can you explain what fault you are reffering to.
    You just say "white titles on black background".
    What do you mean by this?.
    The only thing i can see on the image is a light box type background, but this is because the brightness and colour is turned up too high.
  16. rox
    rox
    You want really to put the test my English... :rolleyes:
    1) With white titles on black background, the screen is full of
    little horizontal black lines/blocks (this is the clearest condition).
    But the fault is noticed also with dark scenes.
    2) Without connecting nothing on the AV entries or sending no
    signal, the screen is FULL of white waves in movement.
    ... I hope to have been clear ... :eek:
    Rox
