Problems with Sony DAV SA-30
Discussion in 'Home Cinema Buying & Building' started by wilco1973, Jun 23, 2004.
  1. wilco1973
    wilco1973
    Jun 23, 2004
    11
    Hi there, I have recently had a problem with my Sony DAV SA-30 shutting itself off with the standby light flashing. What happens is that it starts to read the DVD then after a few seconds makes a horrible click and then shuts itself off.
    I looked through the trouble shooting guide and it stated it could be due to something blocking ventilation grill. I checked this and no blockage. It then stated that could be due to speakers short circuiting, so I then disconnected them all but still it does the same. Its under warranty so I have taken it back to one of Sony's authorised repairers but I was wondering if anyone out there knew the what was wrong or have had similar experiences.
    Thanks in advance!
    :confused:
