Problems with Sky+ 160
Discussion in 'Sky Digital TV Forum' started by jhume, Mar 31, 2005.
  1. jhume
    jhume
    I bought sky plus 160 about a month ago and have been having a few problems.
    I first had a problem with the modem not working at all so we had to call sky to get the machine activated without a call back.
    I then found that the recording of sound on the three top movie channels was not working correctly. It would drop out from time to time and was really unmatchable.
    I then find on Monday when I came back to switched the sky box on It would not come out of standby. I call sky how when through some procedures with me to try and get the box work. They finally said that I had to send the box back.
    My personal view is I think the hard disk as stopped working
    Has anyone else had these problem with sky + 160?
  2. nathanhill69
    nathanhill69
    Oct 5, 2004
    392
    +19
    The audio issue you describe is a known problem unique to the Thomson Sky+ 160 when trying to play back Dolby Digital audio. Sky have been promising a software update since last year that will apparently solve the problem - but when that will happen is anyones guess (Sky CS will tell you it's imminent but they've been saying that for months).
    The other issues sound like a duff unit, get a replacement although you're still stuck with the audio problem.
    Regards
    Nathan
  3. MikeNolan
    MikeNolan
    Nov 28, 2004
    540
    Hereford
    Just had a problem with my Sky+ box (not 160) locked in standby. They're coming to replace it. The annoying thing is there is a collection of programs that I have not been able to watch that are now lost. I am concerned about the 160 box, as there haven't been any advertisements lately to promote it, so suspect they are having major problems with them
  4. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,898
    Returned my sky+160 after 2 weeks,the drop out of sound on sky movies (1,2,3) used to drive me mad.
  5. dubledene
    dubledene
    why didnt you get sky + then upgrade the drive your self ?? i did it saved myself money and had no problems what so ever
  6. Boy Lex
    Boy Lex
    As easy as we all may have found it, if you go ahead and get a sky plus box through sky and then stick a new drive in it, you are voiding any warranty and terms you have with sky, so if you get any similar problems with your regular sky box you have nowhere to turn. I'd say better to whinge at sky until they sort it, or send it back completely and buy a cheap pace box on ebay and upgrade that.
  7. jhume
    jhume
    Thanks to everyone
    I suppose I was hoping that if I when for the latest reincarnation of Sky + (ie160) that it would have been more stable. They may have had more time to fix the issue, but I am learning that all sky related produce do not seam to be fully tested before the company releases the hardware and from my experience because they have no major competitors, in areas without cable, the can provide what ever service they like and we have to either have no sky or some sky for some of the time.
    :thumbsdow
  8. shoestring25
    shoestring25
    Feb 2, 2003
    3,797
    essex
    +395
    if you buy a sky + box and you put a new harddrive in it yes it invalidates the warrenty. but why dont you put the old hard drive in if you have a problem and they need to come out they will be none wiser you have done anything to it.
  9. dubledene
    dubledene
    hardley rocket science well said :clap: :clap:
  10. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    But chances are that any Sky+ problems will be related to the HDD and changing it back would probably solve any problems at the time
