problems with saa7130/pb-tv100 and dscaler
Discussion in 'Desktop & Laptop Computers Forum' started by mince bigalow, Nov 8, 2003.
  1. mince bigalow
    mince bigalow
    hi all, i just got back from pc world and started setting up my new pb-tv100 card (after watching the rally of course) and am having problems. With the latest version of dscaler i cant seem to find out where to set the tv card to be used, in the help file the dialog boxes are different??? With the previous version (3.10) it says no suitable hardware on the splash screen?
    could anyone help me please? I really want this set up so i can record the last day of the rally tomorrow.
  2. mince bigalow
    mince bigalow
    please help me, i really need this sorted by tomorrow :(
    thank you
  3. MikeTV
    MikeTV
    Feb 1, 2003
    7,781
    Ealing, London
    +843
    Once you have physically installed the card in the PC itself, you can try uninstalling and reinstalling Dscaler. Next, start Dscaler and select "LifeView Flyvideo..." from the "Sources" menu. (you may also want to select "define as initial source").
    If all goes well, Dscaler should provide you with a menu entitled "SAA7134 Card", and it is here that you can select the input source (ie. composite, s-video, etc.)
    It worked for me!
  4. mince bigalow
    mince bigalow
    cheers for the help mate, I got a newer version from the site and that seems to work now. Its very clever software, im impressed.
    one other thing that would really help me is if someone could tell me the best way to sort out the noise on the edges I get on text and distinct lines using composite. is there a certain filter I should use?
    thanks a lot
