Hi.
I have an Onkyo TX-SR576 receiver, and I am very satisfied with it.
However, i have a problem with the RC-709M Remote controller.
A friend tried to set it up so I could use the remote on my Toshiba TV, without any luck. Whats worse is that during the process, something weird happend to the remote. Most of the functions works as normal except this:
1) Volumbutton: Its now reverse.. Volum up turns the volum down, and the other way around.. Volum down turns the volum up.
2) Power on and off: This doesnt work anymore, instead everytime i push the On/standby button, the screen switches from "Source (f.eks CD) and Volum (f.eks 23) to "Source (f.eks CD) and the text All ch st".
3) Zone 2: Probably because of the power on and off failure, I can not turn on zone 2 with the remove.
I have tried to reset the remote and also tried to reset the receiver in hope of this issue getting fixed, but its still the same.
Are there anyone out there who could please help me with this issue? Its very annoying not to be able to use the remote control as supposed to..
Thank you very much in advance..
Regards
Mats
Regards
Mats
