Problems with Rear Left Speaker
Discussion in 'Home Cinema Speakers' started by enemy2pc, Jun 12, 2004.
  1. enemy2pc
    enemy2pc
    Oct 30, 2002
    644
    28
    Tyneside
    +45
    Ive had my speakers set up for about 3 months now with no problems until the other day when i notied i wasnt getting any sound from my rear left speaker. When i listened right up to it i could hear a dull echo of the sound that was supposed to be playing. Ive checked all the connections and went along the length of the speaker cables and cant find any obvious faults. Can anyone tell me what else might be wrong and how i might be able to fix the problem.
    My HC set is the Limit HC-40's if that help any.
    Regards
    Bryan
  2. Grimley
    Grimley
    Sep 19, 2003
    968
    4
    2
    47
    Deepest, Darkest Essex, so BEWARE!
    +161
    Have you tried one of your other speakers with that connection, it will determine whether the speaker, the connection or the amp is at fault.
