Problems with ready nas nv+ external connection to ftp
Discussion in 'Networking & NAS' started by tautvydasm, Mar 11, 2013.
  1. tautvydasm
    tautvydasm
    Mar 11, 2013
    17
    Hi, I use Ready Nas nv+ and in local network work well, but then i try to connect from external ip doesnt work ftp. I open port 21 for ready nas nv+, and passive port but doesn't help this steps. Can help to configurate Ready nas nv +? In local network ftp work well
  2. Morphies
    Morphies
    Aug 18, 2008
    818
    Rotherham
    +89
    What errors are you getting when trying to connect via FTP?
    Using a client like File Zilla should give you an informative error. Please post the details of the error.
  3. tautvydasm
    tautvydasm
    Mar 11, 2013
    17
    Error: Could not connect to server
    Status: Waiting to retry...
    Status: Delaying connection for 1 second due to previously failed connection attempt...
    Status: Connecting to **.***.***.***:**...
    Status: Connection attempt failed with "ECONNREFUSED - Connection refused by server".
    Mod Edit: removed IP from post
  4. Morphies
    Morphies
    Aug 18, 2008
    818
    Rotherham
    +89
    You may want to remove your IP from that post.
  5. Morphies
    Morphies
    Aug 18, 2008
    818
    Rotherham
    +89
    OK, so the port is closed on your router. Which means it's a routing issue not a setup issue on your readynas.
    Have you tried putting the readynas in the DMZ to make sure you can connect externally?
    Once you've established an external connection is possible, you can then set up the port forwards.
  6. tautvydasm
    tautvydasm
    Mar 11, 2013
    17
    my port looks (in attachments)
    Can you explane "DMZ to make sure you can connect extermally"?
  7. Morphies
    Morphies
    Aug 18, 2008
    818
    Rotherham
    +89
    At the top of the settings page you have DMZ enabled radial. Enable that and in the IP box put the IP of your NAS
    192.168.1.4
  8. tautvydasm
    tautvydasm
    Mar 11, 2013
    17
    Same error after enabling 192.168.1.4
  9. Morphies
    Morphies
    Aug 18, 2008
    818
    Rotherham
    +89
    Please remove the port forwarding rules named FTP and NAS.
    Save and reboot your router.
    Please post up the port forwarding settings page again after the reboot.
  10. tautvydasm
    tautvydasm
    Mar 11, 2013
    17
    same, not working after that
  11. Morphies
    Morphies
    Aug 18, 2008
    818
    Rotherham
    +89
    Could you post another picture of your current DMZ and port forwarding settings page on your router?
  12. tautvydasm
    tautvydasm
    Mar 11, 2013
    17
    ok
      Size:
      34.5 KB
      139
  13. Morphies
    Morphies
    Aug 18, 2008
    818
    Rotherham
    +89
    Right,
    Adding the NAS IP to the DMZ removed the need for any port forwarding.
    Please remove the port forwards named FTP and FTP-passive. Reboot the router and try again.
    Edit: If anyone else want's to jump in, feel free as it's getting busy at work!
  14. tautvydasm
    tautvydasm
    Mar 11, 2013
    17
    same error
  15. Morphies
    Morphies
    Aug 18, 2008
    818
    Rotherham
    +89
    I'm assuming your still on your local LAN.
    can you make sure you can log in using the FTP client to 192.168.1.4 ?
  16. tautvydasm
    tautvydasm
    Mar 11, 2013
    17
    yes, i can connect to 192.168.1.4
  17. mickevh
    mickevh
    Apr 30, 2007
    7,178
    West London
    +1,716
    In all the SOHO routers I've looked at (which admittedly isn't many) "putting something in the DMZ" opens all ports inbound to the designated host. It's nothig like the "proper" DMZ that a networking expert would recognise. Personally I wouldn't go anywhere near it, especially for a Windows host (which obviously you're not) and I'd open up the minimum number of ports necessary.
    FTP is a bit of a funny beast because of the way it opens ports, especially in "active" mode. Wiki's article on FTP is a good read. However, to get around this most people tend to favour "passive" FTP.
    Because FTP is "strange" it might be better to "practice" configuring the requisite port forwards and addressing mechanisms using something else. "Ping" would be most peoples favourite, but again ping (which uses the ICMP protocol) can be a bit wierd to set up in some cheaper routers. SSH would be nother good candidate. (At time of writing I cannot ping anything using the IP address cited.)
  18. tautvydasm
    tautvydasm
    Mar 11, 2013
    17
    ssh working from external ip
  19. Morphies
    Morphies
    Aug 18, 2008
    818
    Rotherham
    +89
    Mickevh, the aim was always to remove the DMZ and open the required ports. I tend to find putting a device in the DMZ to establish the initial connection easier as it removes any possible issues with the router.
    Step one: make sure it's possible.
    Step two: secure it.
    Unfortunately we appear to be having issues with step one!
  20. mickevh
    mickevh
    Apr 30, 2007
    7,178
    West London
    +1,716
    I don't disagree with that approach.
  21. tautvydasm
    tautvydasm
    Mar 11, 2013
    17
    yes, not work, im still waiting helps:)
  22. Morphies
    Morphies
    Aug 18, 2008
    818
    Rotherham
    +89
  23. tautvydasm
    tautvydasm
    Mar 11, 2013
    17
  24. mickevh
    mickevh
    Apr 30, 2007
    7,178
    West London
    +1,716
    A call to your ISP may be worth a punt. Some ISP's try to "help" their customers by blocking some types of traffic.
  25. mickevh
    mickevh
    Apr 30, 2007
    7,178
    West London
    +1,716
    I've just tried telnetting into 89.127.231.240 on port 21 and I get a response (or at least half a response - the TCP only half opens which could be issues my end.)
    However, that tends to suggest the comms, port forwards etc. are basically there.
  26. tautvydasm
    tautvydasm
    Mar 11, 2013
    17
    no, i just change ip before posting in forum, my ip not this
  27. Morphies
    Morphies
    Aug 18, 2008
    818
    Rotherham
    +89
    I did wonder why I was unable to get any responses.
  28. tautvydasm
    tautvydasm
    Mar 11, 2013
    17
    no, they said that all ports is open and issue is from settings
  29. charles_b
    charles_b
    Apr 28, 2006
    616
    Berkshire
    +91
    In the past I've used a different port forwarding to port 21 on the inside, so outside connection is on port 2021, inside to port 21 using a port forwarding rule.
    That also gets around any 'isp' filtering of tcp ports.
    FTP is a funny beast, you may also need port 20 opened too, but usually that's outbound from inside -> outside and the router should allow this without specific port opening.
  30. charles_b
    charles_b
    Apr 28, 2006
    616
    Berkshire
    +91
