Problems with PS2 Component/AE100
Discussion in 'Playstation Forums' started by popeckia, Apr 4, 2002.
  1. popeckia
    popeckia
    Mar 2, 2002
    59
    London
    I recently bought a logic 3 component av cable so I could connect my ps2 up to the component input on my ae100 projector. All the indications are that I have the right lead, yet I don't seem to be able to get anything at all through the projector.
    I know this isn't much to go on, but is there anything I have to do to get the projector to notice the input? Currently I don't have any other component sources to try, nor do I have anything else I can run component into so it's hard to tell where things might be going wrong.
    My Hi-Definition lead for the xbox will arrive soon so can try that into the ae100 when it gets here but in the meantime, does anyone have any suggestions?
  2. museumsteve
    museumsteve
    Jan 28, 2001
    8,003
    4
    Nth Hampshire
    +1,109
    have you changed the output setting in the PS2's menu.?
    If not then turn on PS2 with no game in and then go into settings. The video output needs to be set to component..
    Hope this helps..if this isn;t the case I assume you've changed the input on the Panny remote.?
    Let us know how you get on..
  3. popeckia
    popeckia
    Mar 2, 2002
    59
    London
    :blush: Have to change a setting in the PS2 menu eh? That would certainly explain a lot.... please excuse my utter stupidity... I'll get my coat
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,421
    Norwich
    +934
    i would be interested in your results, well if you get to see the browser really.
    I only see any picture once the game boots, it may be something to do with my modchip, but would be grateful to hear how you get on.
    cheers
    Guy
  5. oreoboy13
    oreoboy13
    I am in the same boat my Component lead from Lik-Sang turned up today, i chaged the setting in the menu, plugger the lead into the amp, but no pic. I have tried other sources and everything works except the PS2 any ideas? Mine is chipped but i cant believe that would make any difference.
  6. museumsteve
    museumsteve
    Jan 28, 2001
    8,003
    4
    Nth Hampshire
    +1,109
    haven't got a clue chaps, mine works fine and has worked on Origa chipped machine aswell..
    Hope you get it sorted..
  7. Yoleus
    Yoleus
    Apr 15, 2002
    7
    4
    Leicester UK
    Where can you buy a component lead for PS2?
  8. EffTee
    EffTee
    Jan 20, 2002
    196
    Bristol
    +5
    Mine is on its way form DVDCrave - and they're dirt cheap!
    EffTee
  9. oreoboy13
    oreoboy13
    has anyone got any suggestions to my predictament as i am stuck. I dont know what to do to be frank.
    I just did a little experiment; i dont know if anyone else has the Lik-Sang lead but it comes with the three component leads and 2 leads for sound, i just tried the two stereo leads and they DO work , so what can be wrong, i think i will take it down to sevenoaks and use their Multi meter,
  10. popeckia
    popeckia
    Mar 2, 2002
    59
    London
    Shouldn't one of the 3 leads present a black and white image into a composite video input? You could try that and see if that works at least?
  11. oreoboy13
    oreoboy13
    Just tried it i the compsite socket and nothing. Does that mean its the lead then?
  12. popeckia
    popeckia
    Mar 2, 2002
    59
    London
    which of the 3 did you try in the composite socket?
  13. oreoboy13
    oreoboy13
    all of the video ones
  14. popeckia
    popeckia
    Mar 2, 2002
    59
    London
    I'd guess maybe your lead is the problem then, but I really wouldn't go on what I say...
