Problems with Powerstrip and Pt-AE100
Discussion in 'Desktop & Laptop Computers Forum' started by GPMCDERM, Feb 2, 2003.
  1. GPMCDERM
    GPMCDERM
    Dec 12, 2002
    109
    having a few problems with the HTPC thing......I've setup
    my custom resolution/timings in Powerstrip and saved them and
    my only problem is that if I boot the computer while its connected
    to the projector it won't allow me to select the 856x640
    resolution, but I can select it no problem if I boot tothe monitor
    and just unplug that and connect to the projector.
    I'm running a Geforce2 GTS pro with the latest driver and powerstrip 3.30
    Any help would be great.....killing my back lugging the pc and that
    monitor down stairs everytime I want to have a look.
    Cheers.....
  2. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    What monitor have you told Windows you have connected? I found I had to set the monitor type to be one of the Sony widescreen ones - is it 950W or something? (sorry, not at the HCPC at the mo). Only once that was done could I get the Powerstrip settings to "stick".
  3. Lem
    Lem
    Indeed, telling Windows that you have one of those monster sony widescreens such as the FW-900 will let you hold the resolution selected in Powerstrip.
    From System/Device Manager in Control Panel, manually change the driver for you monitor to Sony Coporation - GDM-W900.
  4. GPMCDERM
    GPMCDERM
    Dec 12, 2002
    109
    Thanks a lot.....will try that later on tomorrow
