Problems with Philips 29pt8424
Discussion in 'Televisions' started by Cagra, Aug 12, 2002.
  1. Cagra
    Cagra
    As the subject says I'm having trouble with my Philips 29pt8424 (it's one of those design-line thingies)
    I have tried to enter the service menu on my tv via the 062596 I+ code on the remote, but no service menu appers.
    Instead it keeps showing the channel number in the upper right corner, and it won't go away! I have tried to enter the code another couple of time to see if it changes it back, or if the menu appears, but with no luck.
    It's the same every time I turn on the tv, I have also tried to leave it unplugged for 3-4 hours to see if that help, but it didn't.
    what can I try now ?
    The tv still haves warranty, but I would try you guys out first, since its my only tv
