Problems with Panasonic HD Recorder
Discussion in 'Digital TV & Video Players & Recorders' started by Bill Blyth, Jan 7, 2012.
Tags:
  1. Bill Blyth
    Bill Blyth
    Jul 15, 2009
    46
    Just bought a Panasomic DMR-HQW100EBK HD Digital TV Recorder both SD and HD signals are superb but the colours are a bit strong in that I would like to adjust the colours as it is a bit on the red side. Normally with the video and the Freesat channels I just click the options button on the Sony remote control and make adjustmenrs to colour/cotrast/etc for each one but when I click the options button on the Sony remote control it is not the tv options that appear but that of the HDD recorder and there is nothing within there that gives me the chance to make cxolour/contrast adjustments. Anyone know how I can do this, thanks in advance.
  2. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    Thread moved from the Video Scalers and Video Processing forum.
    Curly
  3. petrev
    petrev
    Jul 4, 2007
    4,345
    TX Mendip - DHR8205: FW4.22 - M1.35Blk
    +1,015
    Sounds like you have HDMI CEC (Bravia Sync on SONY TV ?) enabled on the TV and PVR.
    Turn it off on both and then the TV remote will revert to being a TV remote and you can adjust the TV picture controls.
    Pete
  4. iaint
    iaint
    Jul 4, 2011
    640
    28
    +89
    Hi.
    Isn't there a way of getting to picture options via the TVs home button? Of course, if OP wants to reveal what TV they have...
    Regards, Iain.
  5. Bill Blyth
    Bill Blyth
    Jul 15, 2009
    46
    The solution suggested by Pete has worked it was to switch off the Viera link on both video and tv but only had to switch off the video option which then freed up the tv option allowing me to set colour/hue/contrast/etc and the picture is now OK.
  6. Bill Blyth
    Bill Blyth
    Jul 15, 2009
    46
    Thanks Pete I only needed to turn off the video option that then freed up the tv option to work normally, now have a much better image. :clap:
  7. petrev
    petrev
    Jul 4, 2007
    4,345
    +1,015
    :smashin:
    Thought one might work but . . .
