Problems with my Panasonic DMR-EH50
supermart
I frequently use my Panasonic DMR-EH50 Hard disk recorder to record programmes overnight from my Thompson DSI 4210 skybox. They are connected to a Panasonic TX 22LT2 tv using a Qlink setup. The sound does not record on about half of the programmes. On other occasions the prog will be silent then the picture will suddenly pixilate and the sound will come on. Where programmes are also on on a +1 channel I try to record them twice and often one recording will be silent, the other normal. I use the Ext link function on the HDR so that the Sky personal planner triggers the HDR to record.
I have replaced all the scart leads but to no avail. The Panny is about seven months old and the Thompson about 18 months. The problem did not occur with my old VCR.
Can you offer any advice or opinion please?
