Problems with my Optoma HD300X
Discussion in 'Projectors, Screens & Video Processors' started by AVDavid, Feb 20, 2014.
  1. AVDavid
    AVDavid
    Feb 20, 2014
    182
    Cornwall UK
    +71
    I have been trying to connect up my new Sony Blu Ray S790 player with my new Yamaha RXV-1073 receiver then out to my Optoma HD300X projector. I don't get a picture through and the HDMI light on the front of the receiver just flashes. I have an old Samsung DVD player HD950 and a Sumvision Cyclone micro 2+ file player connected in the same way work fine.
    I suspect its not syncing properly with the projector but I do not know how to solve the problem I've read both manuals.
    In my lounge I have an LG HR 925M combo Blu ray and this does the same thing as the Sony
    any ideas?
    We had a lightening strike hence the new kit, I lost my lovely Yamaha A2 which I had for 15 years my PS3 which was my Blu ray player, my Onkyo 805 was slightly damaged but it is now in the lounge in place of the A2. I used to run the TV from my samsung set top box using an HDMI lead 5M into the Onkyo 805 then out again to the Optoma projector another 4M run this does not give a signal either but I suspect I was able to do this with the Onkyo because it had an HDMI repeater and the Yamaha doesn't
  2. SteveCritten
    SteveCritten
    Aug 13, 2009
    10,985
    Caistor Lincs
    +4,687
    Have you tried the bluray player straight into the PJ to test?
  3. AVDavid
    AVDavid
    Feb 20, 2014
    182
    Cornwall UK
    +71
    Forgot to mention I did try this but the Optoma couldn't find a signal. I connected the Sony player to my Samsung TV and it worked fine so I think the problem is with the projector I have never updated the firmware on the projector but I'm not sure if you can
  4. AVDavid
    AVDavid
    Feb 20, 2014
    182
    Cornwall UK
    +71
    Correction I just tried that again and it says its receiving a signal 480p 60Hz but the screen is still blank?
  5. kbfern
    kbfern
    Aug 17, 2002
    17,929
    Wolverhampton
    +6,093
    Have you put a disc in the player and tried to play it.also if you have 2 hdmi ports on the pj try them both.
  6. AVDavid
    AVDavid
    Feb 20, 2014
    182
    Cornwall UK
    +71
    I have a disc in the player but without seeing the menus I can't start it playing. I tried outputting directly to HDMI 2 connecting directly with the player connecting directly the PJ sees a signal but no menu is displayed
  7. AVDavid
    AVDavid
    Feb 20, 2014
    182
    Cornwall UK
    +71
    I cant for the life of me understand why it works fine with my old DVD player and file player and not the newer LG and Sony players it's very frustrating!
  8. AVDavid
    AVDavid
    Feb 20, 2014
    182
    Cornwall UK
    +71
    I bought my projector in Feb 2012 has there been a firmware update for this model?
  9. SteveCritten
    SteveCritten
    Aug 13, 2009
    10,985
    Caistor Lincs
    +4,687
    It could be the HDMI lead can you try a shorter one?
  10. AVDavid
    AVDavid
    Feb 20, 2014
    182
    Cornwall UK
    +71
    I've tried it with a 3M cable direct into the PJ but the result is the same it says its receiving a signal 480p 60Hz but the screen is still blank
  11. AVDavid
    AVDavid
    Feb 20, 2014
    182
    Cornwall UK
    +71
    When we had the lightening strike the projector was switched off at the wall socket but maybe the input module was damaged by a jolt coming down the HDMI cable which was attached to the Onkyo amp which was on standby?
  12. SteveCritten
    SteveCritten
    Aug 13, 2009
    10,985
    Caistor Lincs
    +4,687
    It might be worth mentioning it to the insurance company it sounds like something may be damaged.
