Problems with my MSI K7N2 Motherboard - Processor only being 1.1GHz
Discussion in 'Computer Components' started by pwalton72, Apr 2, 2005.
  1. pwalton72
    pwalton72
    Hello can anyone help? I recently put my PC together by buying all the parts from the wonderful Ebuyer. All is okay apart from the XP Athlon 3200+ processor. In the bios it states the processor is only running at 1.1Ghz. What do I need to do to change that?
    Much appreciated if anyone can help.
    thanks
    Paul :lease:
  2. Dillz
    Dillz
    Feb 25, 2004
    236
    Gloucestershire
    +8
    The clockspeed of the 3200+ is actually 2200mhz.
    I am not familiar with your motherboard, but check in the bios that the processor multiplier is set to Auto detect. If it is then check in the mobo manual as you may need to set it manually.
  3. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    You probabably need to change your FSB (front side bus) speed in the bios, it might be at 100mhz by default and so you might need to change this to 133mhz or 166mhz.
  4. branny
    branny
    Feb 26, 2005
    3,682
    103
    Pie Land
    +272
    Johnie will almost certainly be right as I have a MSI mobo and thats what I also needed to do. But remember that things work oin halfs, so if the FSB is 333mhz, you will need set this as 166 in the BIOS.
    Alternatively, there maybe jumpers that ned to be configured in a certain pattern on the mobo.
    Branny
  5. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    Might be worth looking for a BIOS update as that may be necessary before the MB will recognise your CPU.
