Problems with my HP140
Discussion in 'Headphones, Earphones & Portable Music' started by Marvt74, May 18, 2005.
  1. Marvt74
    Marvt74
    Feb 13, 2005
    593
    Manchester
    +16
    I dropped my iriver hp140 earlier today and it carried on working fine.
    Then about 15 minutes later it stopped and froze, then i turned it off and on again and it says i have no files on th player but when i connect it to the pc it finds them all fine.
    Not 100% where my receipt it anyone have any suggestions
  2. mattross
    mattross
    Oct 23, 2004
    257
    +6
    If you're careful U could remove the lid and double-check the HDD connector. It may have come loose. The peeps over at MisticRiver can give U further advice: http://www.misticriver.net
  3. Marvt74
    Marvt74
    Feb 13, 2005
    593
    Manchester
    +16
    Yeah i posted over there to :)
    Ended up taking it back to Aria today who accepted its faulty, i wasnt sure about it being the hard drive as it will play fine through a computer.
