Problems with matrix'd xbox ..help needed
Discussion in 'Xbox Forums' started by Mr.D, Apr 28, 2003.
  1. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    Hello
    Had my Xbox chipped with a matrix modchip a few months back and its been fine.Occasionally I'd need to restart it a few time to get it into the evolutionx dashboard but its always got there in the end.
    Now its dead. It seems to boot and the Xbox logo is green (instead of red as it should be ). Thn it drops into an error screen "13" .The chip itself seems to be installed correctly.(just checked it...solid green light).
    I'm assuming the bios on the chip has become corrupted somehow . If I reflash it in the usual manner will that be all I need to do? I won't have to reinstall the harddrive from scratch again?
    Any help??
  2. Mr_Belowski
    Mr_Belowski
    Mar 20, 2003
    777
    63
    Loughborough
    +281
    Sorry dude, as I'm kind of new to this modding stuff myself I can't offer any advice other than to ask on the www.xbox-scene.com forums and look through all the good info on the site
    Hope you can sort it
  3. Daithi
    Daithi
    Feb 12, 2003
    77
    Dublin
    They have a tendancy to move but still give the green LED. This is a false positive result and you will very probably be fine if you can move the chip fractionally. I use a chopstick through the grill on the side for mine if it's not booting, I turn it on while pressing lightly on it and it does the trick.
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    Many thanks for the advice.
    Reseated the chip last night and its back in working order.
    Thanks again
