Problems with JVC32"
Discussion in 'LCD & LED LCD TVs Forum' started by John Boy, Oct 6, 2004.
Tags:
  1. John Boy
    John Boy
    Over the last week, my new JVC 32" decided to turn its self on and off, it usually does this in a matter of seconds, but last night it turned its self off and didn't come back on again, tried switching it on myself, but this didn't work, then after a couple of minutes this time, it turned back on again, getting a bit freaked out now, anyone have any ideas, or had the same problem, or should I just get straight back onto the dealer, who happened to be Digital Direct
  2. KMR855
    KMR855
    Nov 22, 2005
    103
    Stirling
    +3
    I would contact the dealer ASAP
  3. GaryB
    GaryB
    Nov 12, 2002
    5,387
    St Albans
    +1,294
    Pretty much any power supply fault and some screen faults will cause the set to switch off to protect itself. Before you contact the dealer, unplug any SCART leads that you have connected, unplug the set from the mains, wait a minute or two, plug it back in (without the SCART leads) and test.
  4. John Boy
    John Boy
    Thanks guys, but as you will see the thread is two years old now, did change, but have now just upgraded to a Panny
    John Boy
