Problems with Hard Drive
Thyseus
Recently my hard drive that I use to play music off (not my OS HD) has decided to start playing up.
In the middle of songs it stops for half a second then carrys on playing, is my HD playing up? or something wrong with media player?
Phil
namuk
Any Clicking or Noises coming from drive or any other Odd issues? , also you could just Defrag the drive this will help.
Thyseus
No clicking noises, im running windows 7 so it "should" auto defrag Ill run a manual one tonight. thanks for the input
Thyseus
Just Manual will do :), i run this Defrag class program, try the free Version Home Disk Defragmentation Software | PerfectDisk 11 Professional
also try this Free version of Hard Disk Sentinel downloads Install and run , this will say if you have any issues with drive and Logs shown if you have H.D.D Smart enabled in Bios.
Thanks for the tools
Says theres 4 bad sectors in my OS drive but none on the music drive, altho media player is installed on my OS
Might try a different media player and install it on the music drive
namuk
your OS drive with bad sectors maybe causing the freeze on media player running, try that trial Perfect disc.
what drives do you have? as you may be able to Rma the Drive , and use your slave as main for time being.
Thyseus
An 80GB OS drive (Samsung) and a 500GB data drive (Samsung)
Did a full defrag last night so will see tonight how it goes
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
