Problems with feeds to other tvs since getting sky+
Discussion in 'Sky Digital TV Forum' started by Gaz1965, Jun 27, 2005.
  1. Gaz1965
    Gaz1965
    I have just had sky+ installed. First I got wavy lines on the screen then the feeds to the other rooms started playing up. They came twice and finally re-tuned something to get rid of the lines(apparently the signal was too close some other tv channels-something you would think they would have checked in the first place) I still have a problem with the other rooms. The sky in the main tele is fine but the televisions fed from the back of the sky box(from the rf2 socket?) keep cutting out completely about every 30 seconds for about 10 seconds then coming back. To make it worse it did not do it when they came and has now started again. Can anybody suggest what the problem/solution is. I am not particularly technically minded and this is the first time I have posted on this site so try to keep it simple!
    Gaz1965
