Problems with emulator in prontoedit
Discussion in 'Home Cinema Control & Remote Controls' started by monkeyleader, Feb 3, 2002.
  1. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    Hey,
    Purchased the pronto2mb version yesterday and was getting ready to begin the long task of programming everything in. I donwloaded the prontosoftware from the website and it seems to be working - all apart from the emulate button. Every time I say emulate it just says cant open configuration file. This is quite annoying as Id like to be able to see running some of the other ideas.
    cheers,
    Nige
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Silly question - do you have a config file (ccf) loaded into Prontoedit when your hitting the emulator button?
    Might sound daft, but it's easy to forget loading one in first.
  3. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    well I load a ccf file and can view it and edit it and even download - upload to the pronto - but cant emulate :( .. does this emulation software run on windows 2000 - thats what I have
    cheers,
    Nige
  4. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    I'm using Win2k too and it works for me.
    No idea what the problem can be then m8.
    Maybe try and uninstall then re-install the program.
