problems with e55 panny and sony dav s800
Discussion in 'Home Cinema Buying & Building' started by brackenlamb, Oct 28, 2004.
  1. brackenlamb
    brackenlamb
    Oct 14, 2003
    421
    i have just got my panny e55 dvd recorder plugged to my sony dav s800 av system using optical out,
    i use the panny to watch the films but the sound from my sony ,a\ll works great untill i try to watch a dts film
    it only displays as pcm and the sound is stereo as far as i can tell.
    any ideas what im doing wrong?
    cheers mark
  2. wozwebs
    wozwebs
    Jul 10, 2003
    1,196
    +111
    Would like to know the answer to this also
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    CAN SOny accept DTS 5.1 via optical input? HAve you selected DTS sound track from disc and is E55 set to output bitstream? I think it may be SONY's lack of external DTS support.....But there are some PS2 games with DTS 4.0 SSSX Tricky for example....
  4. wozwebs
    wozwebs
    Jul 10, 2003
    1,196
    +111
    E55 on Bitstream causes sound to make white noise. Movies are fine in DTS and DD5.1
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    wozwebs how do you mean?
  6. wozwebs
    wozwebs
    Jul 10, 2003
    1,196
    +111
    Basically I loaded the CD into the E55 and it came up on the box as a DTS-CD. I then set my Sony amp to Auto, to detect the DTS signal, but it only plays in 2 channel. I can then select Pro Logic 2 to get multi-channel sound but it's not really how I wanted it.
    Just checked the manual online and it seems that the E55 outputs DVD-Audio in only 2 channels :(
    I presumed it would just play in DTS.
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    there is DTS 2.0 as well as 5.1 and 6.1 flavours.. is there a DTS menu on disc? or option for 5.1 DTS sound track (films not DVD-Audio)
  8. wozwebs
    wozwebs
    Jul 10, 2003
    1,196
    +111
    there is no menu option, it is just a DTS-CD. I think it maybe down to the fact the E55 cannot play DVD audio tracks in 5.1, only 2.0 :(
  9. MuffKing
    MuffKing
    If it's a 5.1 DTS sound track then it should output 5.1 channels. On DVD-Audio it mixes down to 2 channels but this only applies to DVD-Audio DVD's.
