Problems with Denon AVR2105
Discussion in 'AV Receivers & Amplifiers' started by pauwoo, Mar 27, 2005.
Tags:
  1. pauwoo
    pauwoo
    Mar 12, 2005
    I have just purchased a Denon AVR2105 amp, i connected it all up, put in a DVD in my player, I was almost went deaf, i just turned the volume up 1DB and it was loud, turning down the volume till is was supposed to go off, just meant it was audible even with no volume.
    Turning the volume up or down made no difference it was either really loud or off.
    I connected my DAB unit and found i had to turn the volume almost all the way up until i could hear anything on it.
    I have been through the instruction book and can't seem to see what i am doing wrong, it possible it is just a faulty unit, even without doing the auto set-up i should be able to connect up my speakers and play things back without annoying the neighbours a street away.
    Has anyone else come across this?
