I was going to buy one of these they look blinding but all reviews say DAB is really crap or does not work at all !!! now i really want one and need a fix. I was going to buy a telescopic aerial and use this would it good enough ? does any own one that knows what we can do to fix the pony dab reception thanks.
Nobody can answer your question, because we have no idea of the DAB reception conditions where you live. Indeed, in my house DAB works on the ground floor, but not on the first floor on an indoor aerial.
First you need to check you can DAB where you live, not everywhere can get it. Assuming you are in a normal reception area the Panasonic will almost certainly work, but you might need an external aerial mounted as high as possible.
No problem with the reception in central london that's not issue its the Panasonic has crap dab and Fm reception its well known with all the wall mounted ones check out the reviews on amazon and Panasonic website. I was not looking to use a external aerial but may have to go this way if nobody with this model has any answers or just buy another brand but i do like this model as i can stick it on the wall out the way in the kitchen.
