Problems with ChoicesDirect?
Discussion in 'Movie Forum' started by Barrovian, Dec 1, 2003.
  1. Barrovian
    Barrovian
    Oct 29, 2002
    1,053
    Second star to the right and straight on 'till mor
    +115
    Is anyone having problems with Choices Direct?
    I have not used them since early summer when I pre - ordered LOTR:TTT, then cancelled it as I found it cheaper elsewhere.
    I went back a couple of days ago to order an Xmas pressie on behalf of the other half, and found that my order for TTT was still oustanding. I've tried to cancel it again, but it does not seem to want to go away?? I've been ringing the number 01733236800 but it just rings and rings. They're not responding to e-mails either.
    Any ideas?
    TIA
  2. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    I dont understand that, i definitely received some dvds from them on saturday. Choices are usually very good :confused:
  3. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    They are usually extremely reliable in my experience... do they have one of their shops near you, maybe you could go in and ask them...
  4. Annatar
    Annatar
    I have had exactly the same problem.
    I ordered Alien Quadrilogy, then cancelled and ordered from HMV as I could get it for £39.99.
    The order even now still says outstanding. Even though it's been cancelled numerous times.
    Other orders I have with Choices are still saying Outstanding, even though I received them months ago??
  5. Barrovian
    Barrovian
    Oct 29, 2002
    1,053
    +115
    I finally managed to get a reply on the phone last night. They say there is a 'glitch' on their system. Although at their end, all orders show the correct status i.e. cancelled, posted etc, at the consumer end all we see is 'in progress'. Apparently its been been like that for months, but they don't seem that bothered.:confused:
