Problems with central on sky+
Discussion in 'Sky Digital TV Forum' started by dapex, Dec 14, 2004.
  1. dapex
    dapex
    Jul 21, 2003
    1,082
    38
    +11
    Hi all, I have had my sky+ for about 3 months now, i have it set to record 5mins after a program finnishes but the wife is always complaining that she misses the last few mins of corri and emerdale. I cant believe that ITV runs that far behind so i pressume i am doing something wrong.
    Does anyone else get this problem ( i know it means admiting to being so sad you record the soaps)??
    Cheers in advance
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    ITV do not follow their own published listings nor those they upload to the EPG.
    I assume it's a deliberate act not only to make sure you watch the commercials that precede the soaps but also to spoil that start of conflicting BBC programming.
    You can increase the padding and since you can record two channels at the same time you should always get what you want, even if you are using one of the tuners for "live" viewing two programs back to back on the same channel just means you are likely to get the end of the first program at the start of the second.
