Problems with BBC HD/ITV HD & DVBViewer
babai
My PC current configuration TV card HVR-4000, with HD3200 inbuilt GFX, 4GB RAM, Windows-7. Yesterday i configured DVBViewer, which is working fine for ITV HD and BBC HD. While watiching i had issues with BBC HD, every couple of minutes, i get a blank screen(like a powercut) and back to BBC HD. I dont know what this issue is, if anyone has come across this issue, please guide me.
babai
articulateape
I have come across this on my setup. I'm using Win7 media center to view channels. After some time it suggested to check the tv cable. I recommend you try that too, see if it's loose or not connected properly. Failing that you can try to search for the channels again and see i that works.
Hope that helps.
