I have problems with DVD audio also on my Denon 2200.
Tried my Sting album which came out beatifully, using all teh speakers and some lovely effects where the instruments blend in and out from different places.
Then I tried a classical DVD-A. Nothing. It came up with a menu asking if I wanted multi channel or stereo so I chose multi channel. I have made all the 6 channel input RCA connections from the Denon into the Yamaha. No sound at all.
Manual? Well they ofetn tell you what the buttons do but the language is often so bad that you have no idea what they really mean or, worse, why you would want to do the things they say.
So I looked at all the settings on the Denon menu but couldn't find an obvious answer.
Maybe I need to tell the Yamaha receiver to expect the 6 channel input, but if so why does the Sting album play correctly?
At least I bought it from a BADA dealer and they are normally very helpful, but if anyone has worked this out I'd be interested. I thought I had a resonable knowledge of how to work this sort of stuff but all these new features, settings, types of connection, different video and audio signals- why can't they make it easy to use?
