Problems with an echo!
Discussion in 'Home Cinema Buying & Building' started by South, Aug 14, 2003.
  1. South
    South
    Wondered if anyone could help. Just bought an LG LH-23c6235 sytstem. I am using a scart lead connection only at the moment. When watching DVDs the sound is fine but when I try and watch the t.v through the DVD/VCR there is a time delay between the system and the tv causing an echo and the sound is broken. Is there anything i can do to stop this, maybe using different cables? I have tried through the Rf and S-video connection. Any advice?
  2. Northerner
    Northerner
    Aug 12, 2003
    112
    19
    The land where The Macallan is distilled
    Need a bit more info on yur connections. Are you using an RCA line input from the DVD to the LG system. Are you remembering to mute down the TV sound?
  3. South
    South
    At the moment just using scart straight from DVD into T.V and RF lead. If i do mute the tv I only then get sound purely from home cinema system. Is there no way that I can still use the T.V speakers as well
  4. Northerner
    Northerner
    Aug 12, 2003
    112
    19
    Sorry South, didn't notice that you had re-posted a few days ago.
    Surely the whole point of a cinema system is to replace TV speakers and thereby impove the audio quality. By using the TV speakers as well, you will loose the 5:1 surround attributes and front/rear speaker balance and, of course, you will get an echo due to the signal processing delay
