Problems using EAC
Discussion in 'Headphones, Earphones & Portable Music' started by Matty, Jan 20, 2008.
  1. Matty
    Matty
    Jan 2, 2002
    46
    hi all
    i've tried to use EAC for ripping CD's to lossless WAV but the song info is coming out a bit messed up - the file is in a single string i.e. Beatles - Number Ones - All you need is love rather than identifying the title, artist and album differently.
    in EAC it orders it fine but in other players like WINAMP, itunes or WMP it doesnt recognise the detail.
    I've setup EAC as per the (limited) instructions to put the files into directories for artist & album, is that the problem? should I just leave the files in native format in one great big directory and let the sorting by album \ artist happen at the encoding \ library stage?
    thanks!
  2. amcluesent
    amcluesent
    Aug 13, 2002
    5,240
    Glasgow
    +1,167
  3. r@mside
    [email protected]
    May 29, 2006
    254
    28
    +25
  4. Matty
    Matty
    Jan 2, 2002
    46
    I did try that but FLAC just copied over the dodgy settings.....and I really need AAC or MP3 format for my nano.
    Right now i'm trying Media Monkey on Insane\320kbps setting to see if that works better.
  5. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    flac is just compressed wav with metadata thrown in. you can still further compress the flac into mp3 or aac with no addition data loss as flac itself is a lossless format. there really is no need to be ripping to wave
