Thanks for the info about PhotoME! You might have ended my frustration:
I had the same problem... BUT... apparently we might have the latest software version. Read the email below I sent to Panasonic for details. This might help anyone who has had the same problem! I am awaiting a response:
Dear Panasonic,
I recently purchased a Panasonic TZ-5 Camera. I have been trying to update the firmware, with no luck. Please read this whole email and then get back to me.
It states on your site that you don't need the new firmware version if:
"The firmware update is not necessary if the current firmware version on your camera is Version 1.2.
1. An SD Memory Card must include one picture file at least. Otherwise the firmware upgrade will not be implemented.
2. Set the camera's power switch to ON.
3. Set Playback/Recording switch to playback mode.
4. Press the button , while holding down the [E.ZOOM] button .
The screen shows ( )
VER: 1.1 ----- Camera Firmware version
5. Set the power switch to OFF, after checking this."
I have tried this, and it did not work, so I attempted multiple times to install the firmware. But then someone online told me that if I install a program called "PhotoMe" and open one of the panasonic pictures I took with my camera it would tell me the firmware version. WEll, sure enough.. PhotoMe tells me everything about the panasonic camera I have, and says I have "software version 1.2.0," which is indeed the latest firmware version. So why did the above test not work?? DoI have the latest firmware version?? Please see the info below which I am pasting in from the PhotoMe program,and get back to me, thanks... Daniel ps:here is the info below....
[PhotoME]
PhotoME version: 0.79R17 (Build 856)
[Overview]
File name: F:\my pictures\11222008\P1000703.JPG
File type: JPEG
File size: 83.9 KB
Creation date: 11/22/2008 19:26
Last modification: 11/22/2008 19:26
Make: Panasonic (
http://www.panasonic.com)
Camera: DMC-TZ5
Software: Version 1.2.0
Dimension: 848 x 480 px (0.4 MP, 16:9)
Focal length: 4.7 mm (equiv. 28 mm)
Aperture: F3.3
Exposure time: 1/30"
Program: Movie Preview
Metering Mode: Pattern
White Balance: Auto
Focus Mode: Auto, Continuous
Image Stabilizer: On, Mode 1
Noise Reduction: ±0 (Standard)
Flash: Flash did not fire, compulsory flash mode
