Hi all,
Just registered with this excellent forum, and am hoping to get some advise on a problem I have recording mini-dv tapes.
I've purchased the Sony RDR HXD890 last week and am very impressed. Main reason for purchasing is to transfer video from my Sony DCR-TRV22E mini-dv camcorder and old Hi8 tapes.
The DVD recorder is connected to my Samsung LE32A559P LCD tv via HDMI, the mini-dv camcorder to the dvd recorder via I-link (firewire) lead and the HI8 to the recorder via S-VHS.
HDMI settings on recorder and tv are set to full HD 1080p. Playing a DVD on the recorder gives an absolute perfect picture.
The problem is when I transfer mini-dv to the hdd of the recorder. The edges of faces/hair are blurred/distorted (especially when filmed indoors) and also noticed vertical lines in the picture, mainly in darker indoor shots and red objects.
When playing back the hdd recording the quality has improved slightly, but is still noticeable.
When recording from HI8 to hdd the picture quality is fine.
I've connected the mini-dv direct to the tv via S-VHS and picture is brilliant.
I've also connected the mini-dv via S-VHS to the dvd recorder and again I have the same quality issue as via I-link.
I have tried different HDMI settings on both recorder as well as tv with no result. I have also tried connecting the recorder to tv via scart with still the same problem.
Sorry for the long description but just to show you that I've tried everything I can think of and to give you as much info as possible.
I hope someone has experienced this before (and found a solution
Many thanks!
Ron
Many thanks!
Ron
