problems resizing image for photo comp
Discussion in 'Photography Forums' started by Solomon Grundy, Oct 26, 2005.
  1. Solomon Grundy
    Solomon Grundy
    Nov 1, 2004
    13,632
    oop north.
    +3,301
    I use the provided program to resize my photo but all I get is a little red x in a white box...how can I post my entry now? I am rubbish at this stuff. cheers... :confused:
  2. Zone
    Zone
    Jun 24, 2001
    6,879
    Barnsley
    +2,683
    pm stevegreen mate.
  3. Solomon Grundy
    Solomon Grundy
    Nov 1, 2004
    13,632
    oop north.
    +3,301
    ok, thanks...
  4. Zone
    Zone
    Jun 24, 2001
    6,879
    Barnsley
    +2,683
    No problems, if he's not about Pm me and I'll give you my email address and I'll resize it for you.
  5. Solomon Grundy
    Solomon Grundy
    Nov 1, 2004
    13,632
    oop north.
    +3,301
    thank you...although I don't know whether all this fuss will be worth it for my snapshot...
  6. Zone
    Zone
    Jun 24, 2001
    6,879
    Barnsley
    +2,683
    Its only a bit of fun mate :smashin:
    Have you any photo editing software whatsoever?
  7. Solomon Grundy
    Solomon Grundy
    Nov 1, 2004
    13,632
    oop north.
    +3,301
    Picasa but I can't see where to sort it out in there either...
  8. Zone
    Zone
    Jun 24, 2001
    6,879
    Barnsley
    +2,683
    Mmm never used it mate so can't help you out, however IMO the best and greatest of all free imaging/editing programs out there is Irfanview and you'd do well to download it, fantastic bit of kit :thumbsup:
    I'm sure if some Picasa guru comes along he'll help you out though ;)
  9. Johndm
    Johndm
    Jan 25, 2003
    1,832
    Bedford UK
    +67
    Don't use Picasso myself. :rotfl: but look for something like 'resize' or 'image resize', can't imagine it would be called much else...
    Your looking to resize width to 800 pixels ( the height should do itself?) then 'save as 'image xxxx with a filesize of around 100k. This might mean lowering the quality to reduce the file size.
    Hope this helps..... :hiya:
  10. Solomon Grundy
    Solomon Grundy
    Nov 1, 2004
    13,632
    oop north.
    +3,301
    thanks for the help...managed to do it using the Finepix Viewer I got with the camera...patience is a virtue.
  11. kbfern
    kbfern
    Aug 17, 2002
    17,953
    Wolverhampton
    +6,128
    In picasa to resize do the following
    1. Select picture by single click on picture
    2. Picture is now in picture tray (bottom left)
    3. Click on export
    4. In name of exported folder type say, resize pictures
    5. Move slider on pixel bar to say 640
    6. J peg slider 85%
    7. Click OK
    8. You should now have a folder on your desktop called resize pictures
    9. Your picture should be in there ready for you to use.
    10. If picture is bigger than 120kb (max size allowed by av forum) redo resize using 480 on pixel bar or change j peg slider to 75% or so.
    Easy init.
  12. Solomon Grundy
    Solomon Grundy
    Nov 1, 2004
    13,632
    oop north.
    +3,301
    just tried that too, works like a charm. thanks.
  13. Overlord69
    Overlord69
    Mar 17, 2005
    781
    +55
    I had to disable my firewall "Norton Internet Security" to get it to work.
