C
Canes
I have just got a Pioneer 420, and have been busy trying to connect it up to as many channels as possible. I have connected the recorder to the tv, which has an internal digital tuner which is fully tuned and picks up all the freeview channels. The smartlink connection has been made, but when I search for channels on the recorder, it only picks up the analogue channels despite the fact that around 80 channels or so were apparently downloaded via smartlink. Where have they gone! Is there a trick for getting it to recognise all the digital channels?
If not, is there a way of getting the recorder to record whatever is on screen? I've tried playing around with the connections but have had no luck.
Thanks in advance for any advice you can offer - it is gratefully received.
