problems putin songs back 2 my pc
Discussion in 'Headphones, Earphones & Portable Music' started by diffinking, Apr 1, 2005.
  1. diffinking
    diffinking
    Apr 1, 2005
    198
    BELFAST
    sorry for being a pain but i just got my sony hd3 and when i try 2 put an album back on 2 my pc it says the tracks cannot be tranferred.
    <cannot transfer this type of file to the computer >
    why does it say this its all the albums on the hd3 that do this
  2. dannyjames
    dannyjames
    :( Im having the same problem.
    Also could you let me know how long it takes you to record a cd to sonic stage. It takes my comp about 10 mins. this seems way to long.
    I still have plenty of hard drive left and am using a hi spec pc.
    Why so long :confused:
    Danny
  3. dannyjames
    dannyjames
    Just found this in the trouble shooting section of the HD3 guide.
    Problem-- Audio data cannot be transferred back to your computer from the player.
    Answer--The audio data has been deleted from the computer you used to tranfer to the player. The audio data cannot be transfered back to your computer if the track is deleted from the computer used to transfer to the player.
    :confused: Why would you want to transfer back to your computer from the hd3 if you already had it on your computer. :mad:
