Problems programming iPronto with DV79
Discussion in 'Arcam Owners' Forum' started by Stuart Wright, Oct 29, 2004.
  1. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    13,927
    2
    167
    Birmingham, UK
    +9,662
    Folks, I've tried programming my iPronto with the DV79 but most of the commands don't work.
    Anyone else experienced this?
    Are there any codes or a CCF to download?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    I had a fair bit of trouble getting my RC9200 to learn the DV29 remote. Often it just failed to learn a code and sometimes it would learn it but then the RC9200 just failed to fully control the DV29.
    I think I now have a fully working CCF for my DV29 just simply with trial & error. A bit of a pain, but I got there in the end (I think! :rolleyes: ).
    Mark.
  3. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
    Try using Tonto to learn the codes, then copy them into iProntoEdit... It's usually a bit better at learning difficult codes...
  4. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Are you all setting Remote to "Other" in Setup. That might solve your problems if you didn't do so.
    Dean
  5. Stuart Wright
    Stuart Wright
    Jan 24, 2000
    13,927
    2
    167
    Birmingham, UK
    +9,662
    Sorry but what is Tonto?
    You mean you can set the Arcam to use an 'other' remote?
    Didn't see that. I'll give it a go.
    Thanks to all who replied.
  6. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
