problems playing DVD on a Pioneer 535
Discussion in 'Blu-ray & DVD Players & Recorders' started by tan1415, Mar 27, 2001.
  1. tan1415
    tan1415
    Hi all,
    I have a modified pioneer 535.
    When i play DVDs. Sometimes the picture just stops and get stuck.(Won't continue to play)
    How is this possible? Is it because the DVD is dirty? Or is it a problem with my player.
    Most DVDs are rentals and after i "clean" them they mostly work. But recently my own 'matrix' DVD also encountered this problem.And this DVD is brandnew and not often used.
    So i hope someone out there is familiar with this problem and can tell me what the problem is and if there's any solution to it.
    Thanks alot for reading and i look forward to your input.
