Problems installing windows 98?
D
danny-p
Ive just wiped my p3 700mhz pc hardrive and started a new.
I put the startup floppy in and wiped all partitions, then re-created one as a primary only then i formatted my 80gig hdd which has all gone smoothly.
But now after all hdd is re formatted i'm left with an A:\> prompt.
Whenever i change it to d: and type "install" or "setup" with the win98 set up cdrom in my drive the following message keeps coming up and i,m totally stuck?
"not ready reading drive E
abort retry or fail?
Any ideas as what i need to do to re-install my windows 98 as i'm totally stuck?
Many thanks
Danny-p
hi
C: should be your harddrive A: floppy and you should get the letter of your CDROM as you boot from your floppy. Its been a while since i installed win98 but i think its E: make sure the driver for your CDROM is loading from the floppy.
so if your CDROM is on drive E: change to that drive and try and install/setup or type dir to see a list of files on CD.
Originally posted by pack man
hi
Thanks for your reply....
I tried E: a few times and it was actuall F: somehow, so all is running ok now.
Thanks anyway.
Danny-p
Lyngdorf MXA 8400 - Premium Power Amp Review Teaser #homecinema #poweramplifier #hometheater
Back
