Problems installing a subwoofer
Discussion in 'Subwoofers' started by jananc, Sep 9, 2007.
  1. jananc
    jananc
    We have a Denon AVR1907, and a mordaunt short Avant 309i subwoofer.
    The Sub has left and right line in and line out connections (phono plugs). The amp has only a single phono plug input. We have tried connecting the amp to the sub by using the left line in connection (which I think is what the instructions say), and we have also tried a Y connector to reduce the two cables to one for input into the amp. In neither case can we get the amp to recognise the existence of the subwoofer (using autosetup). Have tried all the suggestions that I can find on line:
  2. Gregory
    Gregory
    Mar 27, 2005
    312
    Midlands
    +9
    I'm not sure if it's a typo in your post, or me being dozy. It reads as if you are connecting the sub to an INPUT on the amp. There may well be one for use with separated 5.1 source, but I suspect what you want is to use the sub output on the amp (it's likely to be a phono socket, and is at line level, not speaker level) and connect it to the input on the sub. I'm not familiar with the amp, but it is unlikely you need to tell it that the sub is there - the sub signal normally is always there.
    Greg
  3. AngelEyes
    AngelEyes
    Mar 23, 2004
    10,617
    Detached from reality
    +1,635
    What Greg says :)
    Also, switch on the sub :D
  4. Sniper
    Sniper
    Apr 27, 2004
    1,294
    +80
    Image of 1907 back panel... look on the right of the image ... there's a section labelled PREOUT, and there's one RCA connector labelled subwoofer - that's the one!
  5. jananc
    jananc
    Thank you - but it still doesn't work!
  6. Gregory
    Gregory
    Mar 27, 2005
    312
    Midlands
    +9
    Might be worth checking that they work independently. Do you know (i.e is either a replacement)? Alternatively, try feeding the sub with something else like an MP3 player. If you have an old stereo you could check the sub pre-out by feeding it into the input of one channel of the stereo and seeing if you hear anything.
  7. Adam Shaw
    Adam Shaw
    Oct 2, 2006
    760
    46
    London, where the Queen lives!
    +99
    As above, and ensure sub is set to 'on' rather than auto.
    Also, check in the amplifers setup menu that the sub out is turned on.
