Problems enabling Hardware Acceleration
Discussion in 'Desktop & Laptop Computers Forum' started by Norvegia, Dec 14, 2004.
  1. Norvegia
    Norvegia
    Aug 28, 2004
    11
    when I enable the Hardware Acceleration in any of the video codecs I use (Nvidia and Cyberlink), I get interlaced-like horizontal lines; if I don't enable it, I don't get it, but the playback is not as smooth as when it's enabled :mad:
    I have a AthlonXP 2350 Mhz and Radeon 9700 PRO and if I install Catalyst 4.6 the problem is gone, Hardware Acceleration works just well.
    I need help desperately :lease:
  2. JayX
    JayX
    Dec 10, 2002
    339
    29
    c-town
    +30
    you'd probably get more feedback on a PC related forum, i don't see how this is directly related to HDTV unless i'm missing something?
  3. beeblebrox12
    beeblebrox12
    Buy a 9800pro or stick to Catalyst 4.6. All Catalysts 4.7 and up have the same problem.
  4. Norvegia
    Norvegia
    Aug 28, 2004
    11
    As HDTV is quite related to PC world (HTPC, you know), I thought someone would know something about this (forgot to say that I mostly get it when watching high resolution video files), and seems beeblebrox12 does.
    And do you know why it doesn't happen on the 9800PRO? I have to say that enabling VMR9 I've been able to solve this problem, but now, the files take longer to load than using Overlay Mixer 2 and, sometimes, I get some flickering in the picture (seems the transition between film and video modes).
    I've been sticking with Catalyst 4.6 since I found this problem, but as I want to play some games too, I needed to update the drivers.
    Thanks for your time.
  5. Kramer
    Kramer
    Definitely more HCPC than HDTV so...
    Moved to HCPC forum.
    :smoke:
