Problems copying dvd's using split disc
Discussion in 'Blu-ray & DVD Players & Recorders' started by pgayler, Aug 4, 2005.
  1. pgayler
    pgayler
    Dec 11, 2002
    30
    Maidenhead, Berkshire
    I am using dvd-cloner II v2.50 to make backup copies of some of my dvds (for travelling purposes) , I copy to Hard Disc first then use nero Burning Rom v6.6.0.8 to write to dvd which then lets me play the dvd in any of my dvd players.
    I am getting a problem with some films that are to big to compress to one dvd and i have to use the split-disc option in dvd-cloner, this works fine to hard disc but when i use nero to write each of the discs i get a 'DVD_Video files compliance error', which i ignore and continue with the write, but the discs are then unplayable in my dvd player.
    Has anyone else had this problem, or has any advice of how i can get round this.
  2. dicky
    dicky
    Apr 8, 2004
    165
    Cambs
    Use DVD Shrink to put the film onto your hard drive at an optomised level so it fits onto a 4.7 Gig disc
    Regards
  3. pgayler
    pgayler
    Dec 11, 2002
    30
    Thanks for the reply, i have downloaded dvd dhrink, and managed to copy one of my films to my hard disc, and then used nero to write the iso off to dvd, all looks fine, i will try and play it through my dvd player tonight.
    Quick question - in the backup option what is the best option smooth, sharp etc ?
  4. dicky
    dicky
    Apr 8, 2004
    165
    Cambs
    To be honest I just leave shrink to it's defaults and make sure "advanced analysis" is ticked. I have not done any comparisons on the smooth or sharp etc.
    If you want the best quality just back-up the movie only (re-author).
    Have a look on the web there are loads of decent guides available
    http://www.videohelp.com/forum/
    The above site is very good.
    Regards
