Problems connecting Sony HS50 to PC
Discussion in 'Desktop & Laptop Computers Forum' started by edhg, Jun 5, 2005.
  1. edhg
    edhg
    I am trying to use my projector (Sony VPL-HS50) with my PC. I tried connecting the composite plug on the projector to the S-Video plug on my Winfast 6800GT video card (using the s-video to composite connection that came with the card). However, the projector could not detect the signal and would not show any picture. Is there a setting that I need to change on the PC so that the projector will pick up a signal?
    thanks
    Ed
  2. DaveP
    DaveP
    This may have nothing to do with your problem but I just connected the s-video on my nVidia card to my TV and if I switch the TV on AFTER the PC has started I don't get a picture. If I have the TV on the correct AV channel before I start the PC, it works fine.
    Dave
  3. edhg
    edhg
    weird! I tried it both ways but no joy. On my laptop at work I press F8 to switch sources so that it will play with a projector and wonder if there is a similar thing that I have to do for a desktop.
  4. DaveP
    DaveP
    Can you try s-video to s-video?
    Dave
  5. edhg
    edhg
    unfortunately not - I dont have a long enough s-video cable to try it with...
  6. UrbanT
    UrbanT
    Jan 6, 2002
    13,271
    Aldershot, Hants
    +3,033
    Hi Ed,
    Is there any reason you are not using the Sony's VGA, or am I missing something?
  7. DaveP
    DaveP
    I think the improvement in pq would be well worth you investing in an s-video cable. Maplin do a cheap s-video extension lead. £5.99 for 3m and £7.99 for 5m.
    Dave
  8. martian1
    martian1
    Dec 30, 2001
    2,409
    113
    Sunderland
    +667
    VGA is the way to connect :smashin:
  9. edhg
    edhg
    Thanks for all the responses. I'm not using the VGA link as I dont have a long enough cable - the PC sits about 5m from the projector. I have a 5m composite cable that I connected with the s-video convertor.
    Since it doesnt work, does that mean I cant use the s-video link to composite at all? sounds like I might need to make a trip to Maplins...
  10. Metric
    Metric
    svideo? eww, buy a 5m vga cable I am begging you.
  11. DaveP
    DaveP
    If you are serious about getting the best picture then buy a DVI cable!
    Dave
  12. UrbanT
    UrbanT
    Jan 6, 2002
    13,271
    Aldershot, Hants
    +3,033
    Firstly, the Sony doesn't have a DVI connector, so this would be a bit pointless.
    You can tell from other responses, the best way to connect an HS50 to a PC is VGA. www.lindy.com offer a 5m 'premium' VGA cable for £25.99. Having spent so much on the projector, don't cut corners for the sake of <>£20 to get the best results :)
  13. edhg
    edhg
    Excellent. Thanks guys for your help, I really appreciate it.
    Incidentally would a DVI cable with an HDMI adaptor (the HS50 has an HDMI not DVI connection) provide a noticeably better picture that would justify the increased cost (c£30 vs c£50)? That would give me the option of using the cable with my monitor as well as the projector (at different times of course!)?
    cheers
    Ed
  14. DaveP
    DaveP
    Sorry about that :oops:
    My HS20 has, so I wrongly assumed the HS50 would too. Just goes to show.
    I humbly apologise
    Dave
  15. edhg
    edhg
    Hi Dave. The Sony has an HDMI connection not DVI - I have altered my post above as I didnt make this clear.
    cheers
    Ed
  16. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    Hi Ed,
    Surely you could use a DVI to HDMI converter? I have an HS20 with a 9M DVI cable and
    am very happy with the results.
    DVI to HDMI has to be the way to go, if not then VGA.
    Where are you located? Let's see if we can get you some local help.
    Mark.
  17. edhg
    edhg
    Hi Mark,
    Thanks for your response. I'm in London. I was thinking that DVI to HDMI might be a better approach. I could get a straight DVI cable (DVI-I or DVI-D?) with a DVI to HDMI convertor, as that would give me flexibility as to what I use the cable with. Would that be a suitable way to go do you think?
    thanks again
    Ed
  18. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    I'd wait for a reply from someone with an HS50, I know JohnS on here has one 1:1 Pixel mapped that he is very happy with. Let's find out what he uses. To get the best/cleanest picture you'll want to use a 1:1 pixel mapped resolution, believe me this can make a HUGE difference. Using a DVI to HDMI with your HTPC screen res set to 1280x720 will give you a WAY better picture than S-Video, COmposite or Component out.
    The cable costs a fair bit but if want a fab pic it's the way to go, if you'll settle for less then why did you buy such a good projector?
    Good luck,
    Mark.
  19. UrbanT
    UrbanT
    Jan 6, 2002
    13,271
    Aldershot, Hants
    +3,033
    Do I not count then? ;)
  20. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    Hehe, Of course you do!, I didn't notice the detail of your reply, I was sneaking a quick peak at work, and I just repeated what you said about the cables.
    Mark.
  21. Metric
    Metric
    I am pretty sure that the only way to get 1:1 pixel map on this projector is VGA.
  22. edhg
    edhg
    I am not sure I follow about pixel mapping (other than it is a good thing). Why would it only work through VGA and not through HDMI?
    Ed
  23. UrbanT
    UrbanT
    Jan 6, 2002
    13,271
    Aldershot, Hants
    +3,033
    HDMI does not offer 1:1 pixel mapping, even with the new firmware update.
  24. edhg
    edhg
    so does that mean that VGA is the way to go then? Or is it a case of going with the DVI-HDMI connection anyway?
    Sorry if I am being a bit thick here, by the way!
  25. UrbanT
    UrbanT
    Jan 6, 2002
    13,271
    Aldershot, Hants
    +3,033
    If you are connecting via a PC, the overriding concensus is VGA :)
  26. paul1672
    paul1672
    Jul 31, 2003
    2,605
    71
    norfolk
    +46
    hey urban,would you mind sharing your base settings for the hs50?
    your pics look fabulous.
    i've tried setting my hs50 up since its return and always feel it looks washed out...
    any ideas?
    paul
  27. edhg
    edhg
    Paul, how come your earlier message hasnt appeared?
    Ed
  28. paul1672
    paul1672
    Jul 31, 2003
    2,605
    71
    norfolk
    +46
    my laptop has been messing up badly and i thought i'd posted my message twice so i deleted what i thought wa sthe duplicate message only to find my message totally vanish....
    not having much luck with anything electrical lately.... :(
  29. edhg
    edhg
    Fair play. Here's one you prepared earlier (I'd be very interested to see how you get on!):
    "because the early hs50's have a problem with the hdmi connection that prevents
    it from showing a proper full screen......
    i know because i'm currently at loggerheads with sony service centre trying to
    get the firmware fix.
    i had to return my pj for a new bulb also and since its return not only did they
    forget to do the firmware upgrade but the machine is no longer quiet....
    after talking to one of their technicians today i was told they know about this
    problem also and that it too will be fixed when i return it (its goin back next
    tuesday).."
  30. UrbanT
    UrbanT
    Jan 6, 2002
    13,271
    Aldershot, Hants
    +3,033
    Hi Paul, I don't think my settings will make any sense to you. I see you have an 868, so assume you connect via HDMI?
    If so, you have far more options in the Sony menu than I have when connecting via VGA. This is because you tweak the PC settings more than you tweak the projector. When you get your PJ back, have a play, and then lets see if we can suggest anything that could help :)
