Problems connecting Sky to H78 via scart/RGB lead
Discussion in 'Projectors, Screens & Video Processors' started by toni_montana, Sep 2, 2005.
  1. toni_montana
    toni_montana
    I am trying to connect my Sky to an Optoma H78 using a Scart to RGB lead. The RGB lead seems to have an extra 4th connector (is this for synch), which doesnt connect to anything.
    However, all Im getting is a scrambled picture. Ive set the source to be RGB but this doesnt help.
    Any ideas?
  2. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    Can't remember if you can do this with the H78, but if you can you stick the 4th sync connection into composite video (yellow plug just nexxt to component input) then select RGB colourspace in the setup menu from the component input. However with the H78 there's a scart-VGA adaptor which you stick in the back of your Sky box then run a VGA lead to the PJ and use a VGA-DVI adaptor setting the DVI-I input to RGB colourspace.
    Or just get that processor you've been hankering for and be done with it ;)
